2 section capped blend without depth specification
llam
2-Guest
I feel stupid !
I want to create a blend as shown with curves in attached zip file.
The triangular sketch on datum plane hor needs to be extruded to pnt0
All blends I've tried, know and understand ask for a depth.
All I want to do is use pnt0 (location not fixed)
Is it me or is it Pro/E that I'm unable to do this......
Can any of you guide me to the solution ?
I'm using Wildfire 3 buildcode M160,
I also have WF4.0 available
Like,
Try using the boundary blend feature (see attached WF 2.0 model). Just
select the triangular base sketch and point (2 curves) in direction 1, leave
direction 2 blank. I defined the top point at a set distance from the base
plane. However, you could use construction geometry in the sketch or
equations (relations) to define the height.
If you need a solid, the surfaces will need to be merged and solidified as
shown in the model.
Chris Thompson
Appian Way Technologies LLC
Powell, Ohio 43065
www.appianwaytech.com
(614) 595-3751
