2D Drawing Export Dimension and other lines color not as per Shown in Graphical area
dg-2
7-Bedrock
Refer below screen shots
1.) view Dimension are in Blue color
2.) view final export to pdf Dimension color changed to Black color
4 REPLIES 4
MartinHanak
(To:dg-2)
colors applied during PDF export are defined in pen table file.
MH
Martin Hanák
mbonka
(To:dg-2)
Hello Deepak G  ,
see following config.pro option:
pen_table_file  --- Specifies a default pen mapping table which supersedes other pen mapping informations.
Pen table is a creo parametric file with *.PNT extension.
See attached file with example of pen table file.
Regards
Milan
dg-2
7-Bedrock
(To:mbonka)
Hello @Milan Bonka,
1.) where i need to save this pen.pnt file in which location.
2.) pdf_use_pentable yes ; im already configured but in default pen table, and location for this i can't find.
3.) I required as per Graphical area shown after export.
all this questions what i need to do.
MartinHanak
(To:dg-2)
you can save pen.pnt file in any directory, for example C:\PTC
Following options has to be included in config.pro file:
PEN_TABLE_FILE C:\PTC\pen.pnt
PDF_USE_PENTABLE  YES
MH
Martin Hanák
