30 Degree ISO Prespective view
ptc-3182477
Dear Sir, We are facing an problem in developing an 30 Degree ISO Prespective view for the Documentation process. Customer requirement is we need to project the Assembly model profiles into an New workplane and put the dimensions in the Workplane. We kindly request you to reply with your suggestion at the earliest.
1 REPLY 1
This is the forum for CoCreate Modeling Personal Edition. You should not be using Personal Edition with customers. Personal Edition is a demo version. If this is a request for help with the commercial version of CoCreate Modeling, you should contact your local help center. It is not possible to add dimensions to workplanes.
