I am struggling to find how to create a 3D curve in Creo 2.
I remember the feature where you would sketch a curve on two perpendicular planes then you where able to use those sketches to create a 3D curve.
Does anyone else remember this feature or has this now been taken away from Creo or just renamed to something completley different?
Colin,
select two planar curves and click Intersect button (see picture).
Martin Hanak
Are you looking for sweep?
Colin,
Martin Hanak
Colin,
For composite curve, select first curve again select the same curve (curve will highlight in bold color) + SHIFT + Second curve > Copy (CTRL+C) > SHIFT > Select next curve > Finish.
