3D PDF parameters
amedina
3D PDF parameters
Hello all,
It looks like 3-D PDF can show all the parameters for each item in a
model tree. You basically open a pro/e part and it reads a simple model
tree. When you click on an item it shows all of its parameters as they
are on Pro/e.
Is there a way to export only some parameters? Is there a way to export
only some parameters? Not only hide them, but permanently make them not
show up? We would like to show only say; description, and ISE internal
part number along with, other items. We do not want to have the author's
name, date it was started on PDMLink, and such unnecessary pieces of
info that a costumer would not want.
Any idears?
Alfonso
Alfonso Medina O.
Mechanical Engineer
Also along with that, is there a way to unlock parameters? I'm thinking
I can go ahead and just delete parameters I don't want on a temp
workspace through a scripted map key. I'm referring to all those
parameters that say "locked" by "winchill" on the parameter info chart.
Alfonso
Alfonso Medina O.
Mechanical Engineer
