Hello guys, I participated in SAE BAJA Competition & I am in design department so that I have to design A-arms for the front suspension. How to deign sketch if we see arm front at 15 degree & if we viewing from top at 45 degree?
Draw a front sketch and draw a top sketch. Then use the intersect feature to intersect the 2 curves in 3d space.
Hi Harshil,
Did Corey's suggestion help you in getting what you wanted? If so, please mark the Correct Answer. If not, please elaborate.
Amit
