A file of format .U3D
VladimirN
Hello!
In Creo Elements/Pro there is a possibility to save 3D-model in a format ".u3d". At me a next question: what program-viewer (it is desirable free, like Adobe Reader for PDF 3D) it is possible to open the given format ".u3d"?
11 REPLIES 11
1) Save your file as PARTXXXX.PRT
2) Save a copy FILE>SAVE A COPY>
3) Use the extension PDF U3D
Thats all. You have a .PDF file with an object you can rotate.
And you can use Adobe Reader to see it.
You can also.
3) Use the extension U3D
There is a program called BLENDER3D, you could try it.
In a while say you if you can use the UD3 file in office.
El mensaje fue editado por: Faustino Garcia
Hello!
Thanks for the answer. In the closed group "Arbortext Galaxy BETA" I have received the following answer:
Right Hemisphere's Deep View are able to view U3D and are free (http://www.righthemisphere.com/products/client-products/deep-view).
Thanks.
Best regards
Faustino Garcia
So, links, and, also, the program "Deep View" were updated, now it is called as "SAP Visual Enterprise Viewer" (in two variants: "Minimum" and "Complete"):
http://www.righthemisphere.com/support/downloads/
http://www.righthemisphere.com/deep_view_eula.php?type=minimum
http://www.righthemisphere.com/deep_view_eula.php?type=complete
Good, thanks.
I think that these links too can be useful (for open of files of 3D-models):
PDF3D (Adobe Reader): http://get.adobe.com/reader/
VRML (Cortona3D Viewer): http://www.cortona3d.com/install.aspx
JT (JT2Go): http://bit.ly/ip4UZ1
Adding to the list:
edrawings: http://www.edrawingsviewer.com/
cosmos player: http://cic.nist.gov/vrml/cosmoplayer.html
And if you use for PDFs:
PDFill: http://www.pdfill.com/
PDFCreator: http://sourceforge.net/projects/pdfcreator/
About Siemens .jt extension, I don't discover how to export a PROE//CREO .prt to .jt yet. I think I look for that today.
Best regards
Faustino Garcia
Hello!
Thanks for links.
I would like to notice also that under the specified link (http://cic.nist.gov/vrml/cosmoplayer.html) it is possible to find many links to various programs and resources on work with format VRML:
...About Siemens .jt extension, I don't discover how to export a PROE//CREO .prt to .jt yet. I think I look for that today...
I think that in it there is no necessity since there are formats for an exchange 3D-given in the form of following formats (in which allows to save Creo Elements): STEP (.stp) and IGES (.igs). Here possibility of importation of format JT is more significant. For this purpose there are a plug-in adapters in Creo View (Creo Elements/View Professional 10.0) which list includes the JT-adapter.
I have a U3D file, but not 3D model of it. Is it possible to save as U3D to STEP or IGES, so that i can use in Pro-E or IsoDraw?
If this is not the 3D model, then it is better to transfer the ".dxf", ".dwg" file formats.
Can we convert 3d PDF to dxf or dwg? Is there a third party software to do that?
