Hello!
In Creo Elements/Pro there is a possibility to save 3D-model in a format ".u3d". At me a next question: what program-viewer (it is desirable free, like Adobe Reader for PDF 3D) it is possible to open the given format ".u3d"?
1) Save your file as PARTXXXX.PRT
2) Save a copy FILE>SAVE A COPY>
3) Use the extension PDF U3D
Thats all. You have a .PDF file with an object you can rotate.
And you can use Adobe Reader to see it.
You can also.
3) Use the extension U3D
There is a program called BLENDER3D, you could try it.
In a while say you if you can use the UD3 file in office.
El mensaje fue editado por: Faustino Garcia
Hello!
Thanks for the answer. In the closed group "Arbortext Galaxy BETA" I have received the following answer:
Right Hemisphere's Deep View are able to view U3D and are free (http://www.righthemisphere.com/products/client-products/deep-view).
Thanks.
Best regards
Faustino Garcia
So, links, and, also, the program "Deep View" were updated, now it is called as "SAP Visual Enterprise Viewer" (in two variants: "Minimum" and "Complete"):
http://www.righthemisphere.com/support/downloads/
http://www.righthemisphere.com/deep_view_eula.php?type=minimum
http://www.righthemisphere.com/deep_view_eula.php?type=complete
Good, thanks.
I think that these links too can be useful (for open of files of 3D-models):
PDF3D (Adobe Reader): http://get.adobe.com/reader/
VRML (Cortona3D Viewer): http://www.cortona3d.com/install.aspx
JT (JT2Go): http://bit.ly/ip4UZ1
Adding to the list:
edrawings: http://www.edrawingsviewer.com/
cosmos player: http://cic.nist.gov/vrml/cosmoplayer.html
And if you use for PDFs:
PDFill: http://www.pdfill.com/
PDFCreator: http://sourceforge.net/projects/pdfcreator/
About Siemens .jt extension, I don't discover how to export a PROE//CREO .prt to .jt yet. I think I look for that today.
Best regards
Faustino Garcia
Hello!
Thanks for links.
I would like to notice also that under the specified link (http://cic.nist.gov/vrml/cosmoplayer.html) it is possible to find many links to various programs and resources on work with format VRML:
...About Siemens .jt extension, I don't discover how to export a PROE//CREO .prt to .jt yet. I think I look for that today...
I think that in it there is no necessity since there are formats for an exchange 3D-given in the form of following formats (in which allows to save Creo Elements): STEP (.stp) and IGES (.igs). Here possibility of importation of format JT is more significant. For this purpose there are a plug-in adapters in Creo View (Creo Elements/View Professional 10.0) which list includes the JT-adapter.
I have a U3D file, but not 3D model of it. Is it possible to save as U3D to STEP or IGES, so that i can use in Pro-E or IsoDraw?
If this is not the 3D model, then it is better to transfer the ".dxf", ".dwg" file formats.
Can we convert 3d PDF to dxf or dwg? Is there a third party software to do that?
