ACIS export issue between Creo 3 and 4
bchapman
11-Garnet
In Creo 3.0 I save a part as a ACIS (.sat) file , I get the EXPORT ACIS dialog box for options. (see sketch)  I select solid and save the file.  I am able to import and open the file in CST software. In Creo 4.0 M050 I save the same part as a ACIS (.sat) file but I don't get the EXPORT ACIS dialog box and it will not open in CST. I get an error message saying there are no solids. Any one have any ideas why the export would be different between Creo 3 and 4?
Hi Randy,
Build M050. I will try the M060 build. Thx.
5 REPLIES 5
Export ACIS dialog box will appear on checking "Customize Export" when saving file to ACIS format. OR You may like Config option Intf3d_out_configure_export as Yes
Hi MaheshSh,
I tried these, but they don't give the option to check "solid or shell" option for export. I also verified that Creo 3 and 4 are both outputing version 5 ACIS.
Hi @bchapman
Can you share that part here? Or submit a case for TS with part file. As far as I Understand, those options should not make any difference in ACIS export.
RandyJones
20-Turquoise
(To:bchapman)
What build of Creo Parametric 4.0 are you running?
In M060 PTC fixed an acis export bug. See articles CS289438 and CS289000:
https://www.ptc.com/en/support/article?n=CS289438
https://www.ptc.com/en/support/article?n=CS289000
Hi Randy,
