It seems like the stock table does not consider AFX created plates, only beams. Is this correct behavior?
Another thing I wonder is if there is any possibilities to export the stock length info from the model itself to a text format, so I don't need to go through a drawing to get this information?
Thanks!
Regards Yngve
(Creo Parametric 11.0.4.0)
Hi @YStrypet
Thank you for your question.
Best regards,
Hi @YStrypet ,
unfortunately both of your requirements are not possible with AFX at the moment.
We do not know what is your base for your plates. With profiles this is clear. you have a defined section with a variable length. Plates can be variable in all 3 directions and that is the reason why we do not add them to the mentioned table.
I hope this helps.
