Access system drawing parameters by Visual Basic.net
bdijkstra
I try to load the amount of sheets and sheet size by the following programming lines:
            parameter(14) = drw.GetParam("total_sheets")
            pvalue(14) = parameter(14).GetScaledValue
            CB_AOP.Text = pvalue(14).IntValue.ToString
Only it doesn't work and gives me the NullExeption warning. With custom parameters it just works.
Please, could you help?
2 REPLIES 2
mender
(To:bdijkstra)
The problem is that 'total_sheets' is not a drawing parameter.  It is a thing you call out in a manner similar to calling out a parameter, so you get at it with a different mechanism than you use for parameters. I unfortunately don't know the VB API, in Toolkit the function you'd want is ProDrawingSheetsCount.
TomasLoun
(To:mender)
In VB API you will look for  IpfcSheetOwner::NumberOfSheets
