Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Hello I am new to Creo and I am going thru the tutorials and during the Sheet Metal Sketch Form tutorial it shows the Add Taper check box, however in my Options box in Creo 8.0 that isn't there. Is there an option somewhere to turn this on so it shows up? Earlier in the Fundamentals I had the same problem where the Add Taper box wasn't missing as well.
I have answered my own question by searching over and over again. I found this https://www.ptc.com/en/support/article/CS137759
It says do this in order to disable:
