Adding "Dark Background" option to the config.pro file
ptc-4168940
7-Bedrock
Hi All,
What do I need to add to my config.pro file to make the "Dark Background" option be activated when I start the program? I know it's easy to go to options and all, but I'd like to get rid of that extra step.
If there isn't a way to do this, then how can I change the color for the dimensions (in both the sketch and when they appear on the 3D model) in the config.pro file? I have searched high and low and cannot figure out how to do this.
Sam
Hi Samuel...
You have multiple options:
  • Set the value of system_colors_file in your config.pro to point to a file containing the settings you like. You can switch to the dark background settings and then save them out using the File->Save command on the System Colors menu (as shown below). Then load that file using the system_colors_file setting.
  • Use a mapkey to reset the colors to the dark background settings
  • Use a trail file and a modified launch command to automatically execute the dark background settings. A full description on how to do this is found HERE
Any of these options will get you where you want to go. Write back if you get stuck.
Thanks!
-Brian
6 REPLIES 6
Hi Samuel...
Thanks!
-Brian
As many mapkeys as I already have, I don't know why I didn't think of that before. Thanks a bunch.
Sam
Or you can set the following in your config.pro:
system_background_color 0 0 0
I did that, but then your dimensions are dark blue and a little difficult to see.
Well, you know what they say: Once you go dark......
It was helpful because it brightened my crap-sundae of a day. Thanks.
