Afx creating same views
vmlakar
Hello i am working increo with afx  and i am building constructions with several diffrent subassamblys that that have some same parts and some same details that i have to show on drawing... i want to put all similar suvasaamblies on same drawing and show left and rigth view and some details and sections next o every subassembly... because a lot of sections views and details are same its a waste of time to make dimensions for each... what could be the fastest way to make dimensions or copy views sections or details together with dimensions... i allredy know i can save a drawing as tamplate and than insert it and move view to sheet? Any better ideas?
Thanks for anwser!!
P.s. sorry for bas english
vmlakar
(To:vmlakar)
i think i found the anwser... i need to convert view to draft grup than i can copy and paste it its the fastest way i think...just anwserd it if anyone wondered xD thanks anyway...
伟曹
(To:vmlakar)
Hello,vmlakar
IF you create the assemblies named <component_name>  with drawing synchornous,
If a drawing called <component_name>.drw is available it will be renamed according the model and copied to the project. In case a drawing with an equal name to a sub assembly / sub part exists it will also be considered!
