I'd like to add a relations editor that has syntax-based text colors, a good set of text manipulation commands, etc. My choice would be Emacs, because I could customize it to look the way I want, define all the syntax-based stuff myself, etc.
Has anyone attempted something like this before? I've seen some discussion of Notepad++ on other discussions, but the advice given there for setting things up doesn't seem to work for Emacs.
Any ideas?
Emacs says it is a Linux based text editor. How are you planning on using it for Creo?
I have played around with using Notepad++, which certainly helps but has 2 disadvantages:
I am looking for a product idea to improve the relations editor, and if I don't find one I will be adding one.
Emacs is not just Linux based. I use it on my PC at work, my Mac at home, and have used it on Unix-flavored computers for decades. If I could get it to communicate with Creo, I'd be able to apply syntax-based formatting and have something really nice to edit relations. I can't seem to get Creo to send it a file, though.
Ahh, the website said Linux all over it and I didn't see anything about windows. Thanks for the clarification.
Can't you just export the relations as a text file on to your hard drive, and then open it with that editor?
I sometimes do this and then use a customized file I created in Notepad++
Edit Creo Relations with Notepad++ instead of the default editor
I also submitted a product idea to improve these relations editors on PTC's end, so if you want you can vote this up too.
