Analysys Feature
PeterBrown
7-Bedrock
Analysys Feature
Hola -
I'm sure someone, somewhere, who if far more clever than me has figured this out.
I'm trying to drive sketch dimensions from an analysys feature (Excel). I can create the feature, I can read in the data from Excel, Pro (Wildfire 4) creates the analysys feature parameter (XL_12_2, etc). I run "Compute" and the data updates....all seems right in the world.
However, when try to write a relation, or a sketch relation, I have no access to this data - it just doesn't appear.
Any and all help greatly appreciated!
TIA.
1 REPLY 1
The parameters created by the analysis feature islocated in the analysis feature itself.
If you want to refer to them you have to direct the relation to look at the feature.
For instance
If you were driving a length value with the following values
Dimension name in sketch - SKETCHEDLENGTH)
Analysis feature id: CONTROLLENGTH
The relation would be:
