Angular Dimension Units grayed out...?
tgiauque
Genii,
Okay, who can explain to me why the "Angular dimension units" drop-down menu is grayed out in the Dimension Properties dialog? I want to set a dimension to "degrees, minutes." I'm working in WF4, M100.
Tim
Tim Giauque
Project Engineer II
FN Manufacturing, LLC
Phone (803) 736-0522 x383
Fax (803) 865-3543
Tim,
This functionality is available in drawing mode only. This option will be grayed out in part/assembly mode.
Check the TPI-121890
~Ash
