Hello All,
I am trying to create annotations in Assembly, by activating a certain part in the assembly.
In which I found that Annotations Tab got Disabled when a part is active,
can you tell me how to create annotations in this scenario?
Hi and HNY 2020
After performing regression tests down to Creo 2.0, the behavior is consistant accross all versions: it is not permitted to create stand alone annotations in the context of an assembly when a component has been activated.
The steps of the scenarios:
Observed: the Annotations group is grey
The solution consists either to:
If you feel like this workflow should be permitted, you may file an enhancement request by following these instructions : https://www.ptc.com/en/support/article?n=CS67713
Is the annotation in the model or a drawing?
Hi and HNY 2020
I wish you a very Happy New Year.
Thank you for your reply, I'm now clear that stand alone Annotations cannot be created in an assembly when a component has been activated.
I would create Annotations in Component(Part) itself.
Thank You.
