Any experienced Pro E expert want to help me make a G650?
ptc-6466036
i just need the fuselage/body of the plane and i will try to make the interior myself, much appreciated!
a lot of job ahead you, but I stick my thumbs.
I do not know if Creo is the best tool to handle it, but if you are going to finally select it, check below comments to help guide you through your task
in short most demanded areas -IMHO regarding Creo - from technical and skills perspective are:
1) nose part(forebody) - here big credits to Jeff4136: you are great!
http://www.mcadforums.com/forums/viewtopic.php?t=2448
http://www.mcadcentral.com/creo-modeling/16928-how-do-you-model-huey-nose.html
https://drive.google.com/file/d/0B60eG4B19bE4TG1ZNzhWTi1tLUk/view?usp=sharing
https://drive.google.com/file/d/0B60eG4B19bE4MlpUYlBrTmdPekU/view?usp=sharing
https://drive.google.com/file/d/0B60eG4B19bE4TG1ZNzhWTi1tLUk/view?usp=sharing<br>https://drive.google.com/file/d/0B60eG4B19bE4MlpUYlBrTmdPekU/view?usp=sharing<br/>
2) wings(airfoil profile)
http://www.mcadcentral.com/creo-modeling/27436-curvature-continuity-analysis.html
http://www.mcadcentral.com/creo-modeling/14708-wing-turbine-blade.html
http://www.mcadcentral.com/creo-modeling/14216-airfoil-blade.html
intermidiate surfacing skills + Creo knowledge required. Luckly you`re in right place to ask for questions
consider to register an account on Mcad Central and mCADForums
http://www.mcadcentral.com/forum.php
http://www.mcadforums.com/forums/index.php
7 REPLIES 7
We're here to help when you get stuck, but I think this is your project to complete.
what is this file type '.stp' i cant open it with Pro Enigneer
yes you can Moody
File > Open > select all files or step from file type menu - see picture below
Thankyou!! What is a step file? sorry im a beginner...
this is neutral file format for different CAD apps.
I think, you should first spend at least a month playing around Creo to get know it, create some basic shapes, products, make some assemblies, etc, and then return to the subject of this post.
it is rather rare, to start such demanded project like modeling an aircraft fuselage body without knowing the basics of software you use to make it.
i have no choice i just moved to a new school and if i dont finish this Graphics Major Project i will not get my High School Certificate
