I am trying to build my input string forODBC_EXECUTE to execute and keep getting an error. when I hard code the string it enters fine into my sql database.
This is how I am building my string:
INPUT_STRING = "INSERT INTO number4 VALUES ('005', " + itos(NEW_NUMBER) +", 'XX', " + MKUPPER(DESCRIPTION) + ", " + MKUPPER(USERNAME) + ", " + DATE + ", " + PROJ_NO + ")"
When I print the input_string variable it looks just like the hard coded one except my new number has increased by 1. Any help would be great.
Here is the template I use for insert statements:
So if you print out your text string from SA and paste that into a query, it works?
What kind of database are you working with?
You can use variables to pass the VALUES into the statement as shown below:
DB table name = number4
DB table field names = description, username, date
DECLARE_VARIABLE STRING string1 "TEST7"
DECLARE_VARIABLE STRING string2 "WBECK"
DECLARE_VARIABLE STRING string3 "10/25/2013"
DECLARE_VARIABLE STRING INSERT_QUERY
INSERT_QUERY = "INSERT INTO number4 (description, username, date) VALUES ("+string1+", "+string2 +", "+string3 +")"PRINT "%" UPDATE_QUERYODBC_EXECUTE UPDATE_QUERY
