Pro Gurus,
Is there a way to create a strong (or even weak or reference) arc length (not chord length) dimension in sketcher?
TIA
Jim Majewski
Sorry, should have mentioned WF 4, M12.
Jim
Another method is while in sketcher: RMB,Select Dimension, pick each arc endpoint then the arc itself and place your dimension.
FYI, this is only for Creo Elements/Pro 5.0. I apologize for any confusion.
