Assembling things
kwsauter
Assembling things
I remember being able to hold down ctl or some other key and being able
to move a component with the mouse, but for some reason, I can't get
anything like that to work. After being away from Pro for a couple
years, my mind has slipped a few tricks into the ever-present black
hole. Does anybody do this, and if so, what is config setting or
mouse/key combination that makes it work?
Ken Sauter
DRS Reconnaissance Surveillance and Target Acquisition
Infrared Technologies Division
PO Box 740188
Dallas, TX 75374
469-221-5430
NOTICE: This e-mail transmission (and/or the attachments accompanying
it) may contain confidential or proprietary information belonging to DRS
Technologies or the sender. The information is only for the use of the
intended recipient. If you are not the intended recipient you are hereby
notified that any disclosure, copying, distribution or the taking of any
action in reliance on the contents of this information is strictly
prohibited. Any unauthorized interception of this transmission is
illegal under the law. If you have received this transmission in error,
please promptly notify the sender by reply e-mail, and then destroy all
copies of the transmission.
"This (document/presentation) may contain technical data as defined in
the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10.
Export of this material is restricted by the Arms Export Control Act (22
U.S.C. 2751 et seq.) and may not be exported to foreign persons without
prior written approval from the U.S. Department of State."
Ken,
Ctl + Alt you can component with the mouse in assembling
Ramesh Chikala
hippe
(To:kwsauter)
Hi Ken,
You can go on ptc.com to the Pro/ENGINEER resource center and download the Quick Reference Card which will help you with many of the features like this in Pro/E:
http://www.ptc.com/community/resource-center/proengineer/
Doug Hippe
EAC Product Development Solutions
