Hey there...
Anyone have any good ideas on how to build an automatic BOM with repeat regions foran assembly family table? Essentially we want to show all the assembly family table instances and the different components for each in one table.
If this isn't possible, what other options do I have?
See attached picture for clarification.
-marc
you can build a table that will display specified column values for specified instances in a family table, i use this alot...but...pro/e can't build quantity counts from that table (which is very frustrating). also, the table will go left to right instead of top to bottom like your picture displays. so, what i do is have leaders notes to each part that is displayed in the table and in the note i specify the qty if the value is more than '1'. in my first attempts using this i did put columns in for the qty (as i've shown in the attachment) but if you have more than a few parts in the assy this will make the table just to wide to use.
(i'm getting an error trying to upload the jpg, if you want to see it i can email it)
