Assembly Reference models grayed out
mwesselski
New Creo user here.   When adding a component to an assembly the assembly is grayed out.  Isn't there a way to temporary switch the grayed out models to fully shaded to help in identifying the surfaces to constrain to? Thanks
2 REPLIES 2
add the following option into config.pro file:
preserve_comp_color_in_preview yes
See https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS211467
MH
Martin Hanák
gkoch
(To:mwesselski)
Hello Mark,
did the hint from Martin solve your issue?
If yes, please get back to the thread and mark Matin's answer as "Correct Answer", to signal to the community that the thread has a resolution.
Gunter
