Assembly causing all my family table objects to show modified
JohnWenner
6-Contributor
I'm using CREO 3.0 currently and WC 10.2.
My issue is, I'm working on a large assembly. I had to swap out one component, saved.  When I look at my workspace, it shows most of my family table instances as Modified.  What is causing the family table objects to get modified?
In addition, one is checked out by a user and I cannot check in my assembly now since it says I don't have access to the part.  I'm a bit frustrated with family tables...any reason why this happens?  Is it possible the the tables did not get verified, and it's trying to do that.  Any settings to prevent this?
0 REPLIES 0
