Assembly distance constraint dragging increments
KevinBradberry
When working with the distance constraint we can grab the white square and drag the component. When I do this the component snaps incrementally every .125". Do you know a way to change the increment size? Or, preferfably, I would like to see a smooth drag with no snapping.
1 REPLY 1
try to experiment with config.pro option named inch_grid_interval
Martin Hanák
