Assembly
aminhas
Assembly
I have a assembly I was copy a same assembly but when I will save as a new name every thing in ok. but than I will going go change the effect on both why? I need little change on new saved assembly what can I do?
Adnan,
Are you asking why a change made to the original is not also changing the copy?
Let's say Assembly_1 is the original and Assembly_2 is the copy. Open Assembly_1, make a change, save, then close. Then open Assembly_2 and the change should not be seen.
aminhas
(To:ClintWalton)
Hello Walton,
I need change in 2nd assembly mean copy. but i will change effect on both. is that any video tutorial?
