Attaching a note to patterned components
lylebeidler
In WF3, I have a pattern of components, and the number of instances in the
pattern is configurable by the end user (can even be zero). I would like to
attach a note to each instance of the pattern, and have it parametrically
update the attachments as the number of instances changes, so that it always
has a leader pointing to each instance of the pattern. Is this possible?
(At this point I'm using annotation features in the model, and just showing
them on the drawing, because it's easier to suppress them off if the number
of instances is zero, but I can switch to drawing-only notes if I have to)
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
Something like this, (from WF5.0), and attached.
mlocascio
(To:lylebeidler)
So, WHO is lucky enough to have the opportunity to be working with Creo
already?
Michael P. Locascio
Lyle,
Is this more what you are looking for. Again attached.
