Hello!
Currently using 20.5.2.0.
First time post from myself. I have been using CREO now for about three years, and feel like I have a pretty good handle on working with it. However, I am yet to find a way to create a render that has a .jpeg images attached to it.
I have a CAD model with a selection of labels currently shown as .jpegs on a work plane which I have attached to their respective locations on the design, however rendering doesn't recognise these images due to them being on a work plane.
Is there a way to attach these images to the CAD model rather than the work planes which will allow me to create a render with the .jpeg images showing?
Any help is greatly appreciated.
Many thanks
You can apply .jpeg files as a texture to model surfaces in Creo.
Example of how it is done.
Thank you for this! Looks like a solution. Cheers!
You're on Creo Parametric board, maybe you meant to be on Creo Elements/Direct possibly? I'm saying this because your software version more closely matches that than Parametric.
If so, we can ask the moderator to move the post.
