Auto filling cabling parameters
AL_13006242
6-Contributor
Working on a decent sized harness with around 2 dozen connectors and have routed all of it in 3D with coord systems and networks. In the past with smaller harnesses I have been able to manually put in the number of pins in the components tab and then in the pins tab add in the entry port, regenerate the assembly, go back into the parameters and the PIN ID and Cable name have automatically been populated. (Not using Cero schematics anywhere all manually routed)
Just as a quick test for this harness I picked a few connectors to make sure everything was working and followed the same process above and the pin ID came in but the cable name did not.
My question would be why is the cable name not coming in? My first guess would be that i need to fill out the entry port column for every single connector ( with that then do I need to do that for every port or just one per connector?). My other guess would be I am missing a step somewhere in there and something is not connecting correctly.
Hi @AL_13006242
Thank you for your question.
Best regards,
Catalina
PTC Community Moderator
PTC
