Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
We migrated from Creo3 to Creo8, and the thing that is very annoying and i cant turn it off, is next. When I work on assembly and than click on part in graphic window, it automaticaly jumps on that part in model tree also.
In Creo3 it did not jump on that part in model tree, You had to right click on the part in graphic window, and than there was option in dropdown menu 'Show part in model tree'. I would like this function back in Creo8, is there a way?
Automatic 'jumping' is sometimes useful, often it is not. I seem to spend 30% of my time just scrolling through model tree to find things. I have a lot of skeleton sketches in assembly model tree, that are used on multiple parts. Now averytime I activate the part in graphic window, it jumps to that specific part in model tree, and I have to find that sketch so i can choose it (for a pattern for example) again.
try AUTO_LOCATE_IN_TREE config.pro option
Thank you! That was exactly what i needed!
