BOM creation
emathivanan
2-Explorer
BOM creation
While doing BOM creation in top only balloons are coming. Sometimes i will be getting error like "Invalid View"? Is there any necessity like views should proper for Balloons creation?
if you use simplified representation in generall view, than BOM ballon source representation have to be the same.
Elango,
Does the reply from Milan answer your question?
Just to add some more information:
Invalid view when creating BOM Balloons will appear if simplified representation of selected view is not identical to representation of table.
In such cases you can change the simplified representation of view from view properties or change the representation of table using Table > Repeat region > Model/Rep > browse the assembly > open and select Rep
