Try inserting this table:
In Reply to Christopher Thompson:
I am wondering how to export a complete assembly in Pro-E WF 4.0 to Excel containing the complete BOM and each sub-assembly level. Here are the steps I am using so far:
If not using a PDM system:
1) insert a BOM table into the drawing,
2) select the table, then
3) Table > Save Table > As txt file,
4) then switch over to Excel & open the .txt file
This works fine but it does not include the each sub-assembly level with all its components. I am guessing I need to change the BOM table in Pro-E to do this properly, and would appreciate any advice on how to do this.
Chris
Thanks for the replies. I received this suggestion from Tech support:
The functionality of exporting a bill of materials directly to Excel is not a current functionality of Pro/Engineer, However as an alternative you can follow these steps to open the BOM file in Excel:
This worked great, except it was missing the part / assembly description. So I was referred to this link for creating a custom BOM
It requires setting-up a *.fmt file containing the following information that is accessed by the config.pro file:
To add parameters in the text of the BOM, use the following formatting characters:
I do not yet know if it will work as this will be a first time setting it up.
Chris
Okay, so far the best results seem to be this advice below. Just add columns to the BOM table in the drawing as needed: description, rev level, material, etc. and I find that it is easier to adjust then trying to generate a BOM directly from the assembly model.
Part of the reason I was having issues is these Pro-E models were generated by another company and they used parameters that our BOM tables did not recognize until I modified the tables. I am considered to be the SolidWorks expert at this company I am working for as a contractor and now they want me to be a Pro-E expert as well (I had not touched Pro-E for a few years until late 2011).
Thanks for all the helpful advice.
Chris
In Reply:
