BOM
rmogensen
BOM
Coming form a Solid works background, can you sent the parameters of a BOM to sort by assembly order & to NOT renumber if an item is deleted?  Can you sent these parameters in Creo?
BenLoosli
(To:rmogensen)
You need to freeze the BOM so it will not renumber.
If you freeze, can you still add to it?  I need to be able to continue to add to the BOM as time goes on.
BenLoosli
(To:rmogensen)
Yes, you pick where to freeze the BOM at and it only freezes below that point.
You can add new lines, insert new lines and delete lines above the freeze point and they will renumber.
Lines deleted below the freeze point will not cause a renumber.
