You are asking why when you are importing a STEP file into Creo it does not make solid geometry from the import feature? This happens with some files, and it can be caused by many things. Post the STEP file here (put it in a zip file) so we can review the data and results of the import.
If you want a quick fix, open the STEP in Spaceclaim and then export it is a solid STEP and try importing this into Creo, it may resolve the problem.
If you want to learn how to deal with this inside Creo then start by reading this article.
It could be as simple as an accuracy problem; you could try using the external accuracy setting on import (see above article).
@tbraxton wrote:You are asking why when you are importing a STEP file into Creo it does not make solid geometry from the import feature? This happens with some files, and it can be caused by many things. Post the STEP file here (put it in a zip file) so we can review the data and results of the import.
Thank for your help , sorry but the 3D file can't be shared ... but i'm going to check the link you gave me.
There are a few things you can do to possibly improve the results.
During the import, select Details.
The model accuracy, I feel is the most important. The math between different accuracies rarely works well. You can turn on the repair options but understand that surfaces will be changed.
Thanks for your help ,
I agree with you about the model accuracy , but unfortunatly , it comes without this information .
Regarding the options i'm going to try .
In addition to what kdirth said, I also uncheck all options on the surface tab (G2 fix, simplify surfaces, etc).
I want the STP file to come in with as little modifications as possible.
In my experience, the automatic fixes make things worse 99.999% of the time.
Thanks Aputman ,
i'm going to check the options in order to see if it's better with or without these options.
Best regards
