I have a location that I wanted to mark with an "A" and I thought maybe I could sneak around a note by using a baseline dimension and using @O. It doesn't seem to work in that I get "A.000". Just wanted to see if that was "normal" behavior for base line dimensions.
Thanks, Dale
It works for everything but the ".000" dimension.
Yep; seems to "work to specifications" ![]()
There is a way... use @S and rename the dimension to B
Pro|WorkAround^TM # 1,958,776-D
