I have a sheet metal bin that was initially 26.69" from side to side. I want to reduce that by 7". At 19.90", Bend_Back_1 fails. I found that @ 20.48" and larger the bend back works and @ 20.47" and smaller the bend back fails.
I cannot find a reason why things are failing when they do. Please find the attached file in a .zip file.
Hello @Dale_Rosema
Most of the time, as @Patriot_1776 said, it's enough to modify acuracy in this kind of situations. In this specific one however, i't'e not enough (even with accuracy_lower_bound 1e-5). Better than a long explanations, I registered a little movie showing that:
Consider this just as a guidance with a willingness to help you getting rid from the current issue, but for sure not as a "resolution". In my opinion, I do not see any valid reason to justify why it's not stable in original conditions (with the Flange Walls 4 & 5), so that:
I attached also in this post the result (bin_ts.prt) of what I did in the movie fo your reference. Just be careful with this model, as I did the dimensionning very quickly, so that you may need to modify slightly some positionning dimensions of the holes (supposed to be the corner reliefs).
Serge
I took out the bend relief holes and it seems to work???
Specifically Hole #3 & Hole #4. Why?
If I change Hole #3 from .400 to .500 it works and so does hole #4 and the bend back?
0.407 works (but not .406)
'Sup Dale!
I haven't looked at the file, but it sounds like an accuracy issue maybe? I don't play much with sheetmetal, but it might be something to look into.
Best of luck!
Hello @Dale_Rosema
Serge
Since I found a work around with the hole size and since this is critical, I am calling your response the answer, but just living with a slightly larger drain hole.
Hey.
Since this isn't rocket science and just a drain hole on a fixture bin, I can live with it at a slightly larger drain hole. So I am not going to pursue it further. Just another quirkiness of Creo popping it head up every now and then.
Dale
Creo quirkiness??? Say it ain't so! LOL 🙂
I think part of the issue is how you are using the program. Specifically Flange 4 and Flange 5 have a 0 inside radius. A better way to achieve the box would be to create the bottom, create a flange around bottom (Shift selecting all fore sides) defining the corner relief, extend the back, flange the top and sides, and extend the top. Attached is a quick example in 7.0.
I have to take a look at this later since we are on Creo 4.0.
Thanks.
I created a new bin.
I used the shift key to do all four sides.
I extended the back.
I create the top three flanges and extended the top.
Bin will not "Bend Back" no matter what I tried.... that is because I was suppose "Unbend", which once I did, worked fine. 🙂
A lot simpler model tree thanks to the shift key and selecting the (4) side and then learn to extend one of those side.
