Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
You can make your part A a family table driven part. Add the cosmetic features to the family table and create an instance A1 that matches what you want to merge into part B. Then replace A with A1 in your Merge.
