Blending Surfaces
breiter
Blending Surfaces
Is there a way to blend two surfaces together, the first screenshot shows sort of what i want but was done using drafts and radii to get close, but i havelittle control of the center point of the radius. The second sreenshot shows the two surfaces i want to join, with the exact location of the ball where it needs to be.
If i knew exactly where the two surfaces are going to intersect maybe i could do a VSS. ISDX would sure be nice.
WF3
breiter
(To:breiter)
Wow, That was quick Thank youJanet.
Maybe you could use blend section to surface?
http://communities.ptc.com/blogs/vpalffy/2011/06/02/blend-section-to-surfaces
Thanks All,
Brad
