Blending of curves
rnithinmanohar
Blending of curves
When we blend two curves, surface will be generated between those curves. My question is on what basis the surface is generated and tell me what is blending exactly
Hi Rayudu,
Are you referring to the Boundary Blend tool?
If so, you can control the blend using the boundary conditions, influencing curves, etc.
