The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Hi Everyone,
When ModelCHECK is run on an assembly on "All Levels" the following files are generated for the top level assembly:
<asm name=">.a.alld.html
<asm name=">.a.alld.js
<asm name=">.a.alld.xml
<asm name=">.a.dabom.html
<asm name=">.a.dabom.xml
<asm name=">.a.datmp.tmp
<asm name=">.a.dsumm.html
<asm name=">.a.dsumm.xml
<asm name=">.a.html
<asm name=">.a.js
<asm name=">.a.xml
However; the link for "asm models" in the upper right of the HTML report links to the <asm name=">.a.abom.html. This file does not exist! I have fixed this issue by correcting two java script files that generate that link to link to the <asm name=">.a.dabom.html.
Corrections:
mctopban.js (Line 81): asmBomStr = asmMdl + '.a.dabom.html' ;
mcprntopban.js (Line 52): asmBomStr = asmMdl + '.a.dabom.html' ;
Is ModelCHECK failing to produce the <asm name=">.a.abom.html file or should the link really point to the <asm name=">.a.dabom.html file?
WF 4.0 M130
Patrick Williams
Sr. Systems Engineer II
Mechanical Engineering Solutions
Missile Systems
Raytheon Company
+1 520.545.6995(business)
+1 520.545.6399(fax)
TU/M12/8
6221 S Palo Verde Rd
Tucson, AZ 85706USA
www.raytheon.com
This
