Hi everybody
sometimes I use bulk item parts in assembly.
In the BOM table on drawing I see the BOM_REPORT QUANTITY parameter.
Is it possible to see, in the same table,
the Unit_quantity and the Unit
which are two characteristics of that parameter ?
Thanks a lot
Bye
Pier
Ok, I did not read very well you question.
After a look to support, I found this : https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS122116&art_lang=en&posno=1&q=report%20unit&ProductFamily=Creo…
It says :
Hi
When you edit the parameters of the bulk item, you can add the column "unit" to the table to see the units. By default the parameter "BOM_REPORT_QUANTITY" has no unit. If you right click on the parameter you can add a unit by selecting like below.
Here's what you can get ones it's done.
I suppose you can then call this in your bom table.
Thank you Raphal,
Yes, I added the unit on the Parameter panel, but the problem is just ...
how to recall this info on the BOM table on the drawing.
Bye
Pier
It says :
Great , it works !
Thanks a lot ....
regards
Pier
