Hello To All,
Can you take a bulk item on an assembly and have two quantities on a bill of materials on a drawing? The bulk item has the same part number and the assembly has the same part number. Is there a relation you can write to drive the quantities to what it needs to be? I hope I have explained this enough.
Thanks Billy
You can add a bulk item part twice, but it it takes some work to give them separate report index numbers, which I am guessing is what you mean by having two quantities.
If you have a diagram of what you expect the result to look like, even something drawn with Paint, that would help clarify the result you are looking for.
i will have to do this on Monday morning...there might be something that can be done with relations or something.
