Bulk Items
ScottCrowe
Bulk Items
WF4 - M150
I am looking for a way to identify Bulk Items in the CONDITION.MCC file without adding any parameters to key off of. At first I used an IF statement using model type.
IF (MODEL_TYPE NEQ PRT_SOLID) AND (MODEL_TYPE NEW ASM_DESIGN)
This works fine when I save the Bulk Item itself. However, after adding that IF statement into the CONDITION.MCC file, whenever I save a DRW, Modelcheck uses the MCS and MCH files I identified with the bulk items. This behavior is regardless of what model type the drawing model is. When I save from the PRT, ASM or Bulk Item window (relations) the correct modelcheck config files are used. When I save from the DRW, the IF statement I created for the Bulk Items is used. If I remove that IF statement, then the ELSE statement is used.
So, first question is how to identify a BULK ITEM model type in the CONDITION.MCC file (without using additional parameters if at all possible)?
Second question is how to have the proper model check files read when a save is performed from the DRW?
I have attached a sample of the condition.mcc file
Any suggestions would be appreciated. Thanks
Scott
Scott,
Have you looked at using Bulk_Items in the checks checks.mch ?
Then it would show up in the report form after running modelcheck on the assembly.
BULK_ITEMS (Bulk Items)
Y/N/E/W
Reports any bulk items found in the assembly.
Suggested Settings:
Inter
Batch
Regen
Save
Y
Y
N
Y
Thanks for the reply Don,
That particular checks works fine and does report back if a bulk item is in an assembly.
We have different parameters and requirements for a bulk items versus a solid part, so I'd like to identify whether it is a bulk item or not in the condition.mcc file. Once it is identified as a bulk item then different configuration files can be used.
More of an issue to me is the fact that when a DRW is saved, the model type IF statements are ignored and the ELSE statement is used regardless.
I would assume that when a drawing is saved the primary drawing model is used when executing the if statements that involve Model Type.
Scott
