Pro/Users,
Can "color" of a part be called out as a parameter into a family table and have different instances having different colors?
I would appreciate any reference or similar experiences.
In Reply to F S:
As I mentioned:
You can assign an appearance to different materials, and in a family table you can swap out the materials in each instance for the appearance you want. You have to add all the materials to the generic, and then add the "PTC_MATERIAL_NAME" parameter to the family table. Then it will give you the choices of all the materials currently loaded in the part. However, this doesn't work in WF3, and it sort of works in WF4 but only if you do a secondary regen. for instance, I have made family tables of fasteners with different materials, and at the assembly level it will give all the fasteners from that table the appearance of the last instance constrained, until you do another regen. I sure wish they'd fix this......
In Reply to Luke Diventi:Pro/Users,
