I am trying to make it so I have my tolerance option in my config file set to yes, but when I do this all my dimensions show with limits. I would like to change that setting to NOMINAL so I don't have to edit every dimension just to show one tolerance. I checked my config options and saw there was a tol_mode setting with the little red NO circle (this was set to limits). I am assuming that the option was not functioning properly, so I deleted the option and it will not allow me to add it back in to my config settings. I did some more checking and tried to add the setting to my drawing properties menu to no avail. Did PTC get rid of this option so now i "get" to edit every dimension value so I can show the one tolerance that I was shooting for?
Tim
