CREO Distributed Batch run fail
PL_14410747
2-Explorer
I am using Creo Parametric Release 8.0 and Datecode8.0.3.0
I used CREO Distributed Batch to run DXF export mapkey task but keep failing, I've confirmed there is no any Creo launch initialization dialog box pop-up when running CREO client and I tried both default export task type and my mapkey they all failed. I don't see any log file generated. I ran my mapkey manually and it did work successfully
1.] I do not understand why you start ptcdbatch as Administrator. Run it as logged user.
2.] I suggest to not use One drive directory ... move configuration to standard local directory.
Martin Hanák
