CREO Programming in Creo Version 8.0.5.0
I am trying to automate the model generation of an assembly using Creo Programming. I am able to get to the point where I can read a file with all the inputs and generate the model. But after reading the file, I have to regenerate the model several times (almost 6 to 8 times) to completely get the final assembly. I want to automate the regeneration process as well. I am pretty new to Creo programming and I wanted to know if it is at all possible to write something in the code which can auto-regenerate the model for me and will give me the final assembly right after importing the file. Thanks for your time in advance.
