Cable won't see network when routing
riaea
7-Bedrock
I'm routing a cable that splits off into 2 connectors. The problem is it won't route using "via network"
It shows the simple cable route path. This is weird. It worked fine in the old Creo I thought. Any ideas?
riaea
7-Bedrock
(To:riaea)
After talking to Sandeep Desai. He figured out there is a "bug" in Creo Parametric 2.0 build m050, it was fixed in build M090.
riaea
7-Bedrock
(To:riaea)
