Hi again,
Im wondering how, if possible, I can hide or display certain features in different views of the same drawing. For example, in the image I uploaded, I have two coordinate systems, and I want to display only the Blockup csys in Top view 1 and only the OP1 csys in Bottom view 2. This image it doesnt actually matter so much, but when I have some jobs with three or four co-ordinate systems all overlapping or nearby to each other it can get real confusing.
Nick,
yes, you can, but it is little bit complicated.
1.] set the following detail configuration options in your drawing
draw_layer_overrides_model yes
ignore_model_layer_status yes
2.] in the model create layer for every single CSYS
3.] in the drawing ... REPEAT the procedure for every view
Martin Hanak
In general, these items are managed by layers. You can specify layer status unique to every view.
Nick,
Martin Hanak
Martin, I am not sure #1 is required. I don't remember setting this for anything and I manage layers per view directly.
Of course, combined states can also be used.
Antonius, What do you mean by combined states? I've seen the dialog box popup when i enter a drawing asking what combined states I wanted, but I thought that was just fro exploding assemblies and such?
-Nick
When you right click a feature in the model tree, you can "remove from state". This is one way to create a simplified rep. Use the view manager to create the simplified rep. Then use the All tab to create the combined state...
Note that you can also manage layer states with Combined States.
Note: this is only applicable in Part mode.
Hi MartinHanak,
I tried setting those config options in the config editor and they weren't there. I then opened config.pro and added the options manually but they show up as red circles in config editor as if it doesnt understand them. A
I tried doing everything you said but once i get to step 3, i cant seem to find the combo box with the views inside it, instead i get a combo box with other stuff inside it and this seems to not change no matter how many views i add.
Nick,
options mentioned does not belong to config.pro. These are detail configuration options. You will see them when you open a drawing and then click File > Prepare > Drawing Properties > change in Details Options line.
Do not forget that the change you will make is valid for active drawing, only.
Martin Hanak
Martin,
Ahh ok i will have to retry this when I get in work tomorrow morning. Thanks!
- Nick
I opened a default Creo 2.0 session. I picked an assembly with CSYS at various levels.
In order to show a specific one, I needed to layer them all.so they could be managed. That way, if the model display state changed, it wouldn't change the drawing. This is always a danger with hide in the model.
There are no special settings required in the .dtl file. The drawing tree has its own unique layer manager for each view. As always, it also has the save status to frustrate newer users (right click in the pane).
Martin I found that these two options can be turned on and off easily via this menu:
rather than having to go through the drawing config.
Nick,
you are right.
Two option accessible via Uiser Interface are associated with two following detail options:
Martin Hanak
I don't understand all the fuss over csys in drawings ? all I do is Just Hide the the coordinate systems that I don't want to see in my drawings in the model tree. Then print my drawing. It's not a permanent thing but I generally only print my drawings one time and I do a lot of manufacturing drawings (cam sheets for cnc operators) every day.
Ok I figured out what you guys were talking about now!! disregard my previous post I now see that it is in multiple views on the same drawing now... I really need look a lttle closer at the posts.
Steve
In general this discussion can be applied to a lot of things. There is nothing more annoying to have a perfectly good drawing messed up when some yahoo unhides everything in a model and save the layer state. Knowing about drawing layer states can mitigate some of that.
Oh dear it looks like I'm that yahoo you're talking about haha I've done that a couple times ![]()
We are all yahoos at one point or another ![]()
Let us know if we solved your issue.
Hi again,
I finally got it to work at work. I did these steps at home and it worked perfectly and easily first time, but for some reason when at work I couldn't get the drawing views to show up in the layer combo box. If you look at the picture I posted in my comment above you'll see it shows the part and mfg files in the combo box and then all this white space where I assume the drawing views were supposed to be. I couldn't select the white space either. Even using the selection feature (the little arrow button) it wouldn't allow me to select the views!
I've found out however that after setting both the checkboxes that MartinHanek suggested, found in the menu in this image
, I could now select each view using the Select feature and in the combobox after it refreshed. Interesting that I didnt need to set these checkboxes at home, but I do at work. And that some of you guys claim not to need to turn these checkboxes on/off either.
Any ideas?
There must be a config option set somewhere that is not allowing your work configuration to do this. Now you have-written their desires and you can do what you want ![]()
I always maintain the default installed configuration of Creo to test such things. ...just in case!
You did notice that I accessed the drawing layers from the Drawing Tree, not the Model Tree, right?
Yeh I tried both to the same result
Check config.sup as well or look at the current session config listing.
I'd leave propagate status unchecked. I've looked for other documentation, but haven't found any that describes what it does. I thought it forced upper level visibility changes to all sub items with the same layer.
What you may find interesting is to select No submodel layers. This limits seeing or selecting lower level layers.
Nick,
I am almost sure that:
1.]
Some of your config.pro files contains the following option:
drawing_setup_file PATH_TO_FILE.dtl
2.]
In PATH_TO_FILE.dtl two following options are set differently, than mentioned below
3.]
When you create a new drawing, Creo copies the contents of PATH_TO_FILE.dtl into the drawing. This is very important !!!
Martin Hanak
Perfect answer, exactly what I needed thanks Martin and everyone else for your contributions!
